I set the bench power supply to 6V and about 100ma on the current limit and powered it up. The word 'LOST' appeared briefly, perhaps an omen? I pressed the on key and nothing happened, darn. I poked around a bit more and when I hit the PRGM key a few characters on the right hand side of the screen came on! I played around a bit more and it was all very confusing and uncalculator like. Hitting the ALPHA hit let me type characters and only about 6 shoed up on the right side of the screen. After another few minutes it dawned on me that no all of the LCD leads were making contact.
All the solder joints looked OK so I started ohming out each ribbon to the trace if connected to, just past the solder joint. Three of them on the left side of the screen were open. The troublesome ribbons were desoldered and then it was clear that when the ribbons had gotten knocked loose it pulled up about 1mm of trace. Since the traces were not covered in solder mask I thought I could solder to them, but trying to go from the tiny traces on the LCD to the main PCB would not work as the traces would break again in short order. After puzzling on it for a while I pulled some strands out of a stranded wire and formed them to match the traces, tinned the traces and wire strands and soldered them from the trace to the original ribbon pads on the LCD. The wire strand was then folder back and soldered to the main PCB.
It works! Two bodges and it is working again. I can't sell it in this state as who knows how long my wire strand repair will last, not to mention the batter contacts are shot, oh and the screen cover is still broken...
