Please help
I want to find the connection point between the mainboard and the dc-dc red wire in 4 pin connector. Which device on the mainboard (in the red circle in the first picture) does it connect to and what is the voltage?
Where does it connect to? I can't see the circuit in the middle layer. (Left side in last picture ) where connect to component
Thank you for help
