Hello,
I noticed in the HP427A servive manual that the HP part number for the SU527 P-channel JFET is 1855-0023. There's a downloadable 143 page HP components cross-reference listed at this link...
www.sphere.bc.ca/test/hpparts.html#crossUnfortunately, of all of the thousands of components listed in the pdf, HP part number 1855-0023 is not included there. On page 16 of the 143 page pdf HP states that components that were made exclusively for HP (presumably having certain characteristics such as this JFET maybe having a particulartly low Cgs for example) are not included in this xref.
(you may still want to download the pdf file because it may prove helpful in the future)
It would be pretty pricy when you include shipping, but it seems that Tucker Electronics has the HP 1855-0023 in stock at $5 each.
www.etestparts.com/Search.aspx?Search=1855-0023---------------------------------------------------------------------------------------------------------------
Also, like david77 previously mentioned, you very well may be able to get away with using an appropriate generic p-channel JFET for Q6. The meter may work fairly well with a substitute Q6, but just not quite meet all of its published performance specifications.
By the way, I really like HP meters from that era. My HP410c's 700MHz bandwidth really comes in handy sometimes. Good luck with your meter repair.
Regards,
Frank
