Correction: The 2 wire reading is 1.5xxx (correct) and the 4 wire reading is 1.2yyy. The error does not scale. Of course, it's so small for most measurements in the higher ranges, it appears that the 4 wire readings are correct.
I removed Q301, Q302 and clamp Q309, with no effect.
I checked Q303, and even substituted another part, but there was no effect.
I've got to be missing something. I just can't figure out what could be causing the 4 wire reading to be wrong without affecting the 2 wire mode.
