Author Topic: HP 5347A Fails HP-IB Test  (Read 959 times)
Offline mbielmanTopic starter
« on: February 07, 2020, 09:37:34 pm »
Hello. I repaired an HP 5347A (20GHz freq counter) and this unit did not have the HP-IB interface option. I found one, installed it, and it fails the HP-IB power on self test. Installed a known good interface card and still fails. Continuity from the motherboard is good and the 5V supplies are fine. There are no option jumpers anywhere that I can find and the manuals make no mention of this... just install the card and that's it.
Wondering if I have a firmware rev issue or some such thing.
Anyone have experience with this?
Appreciate the help.
Thanks.
Mark B
Offline jfphp
Re: HP 5347A Fails HP-IB Test
« Reply #1 on: February 08, 2020, 10:35:30 am »
You have probably to enable the option in the configuration EEPROM on the CPU or, if no EEPROM, to change the firmware in the EPROMs
« Reply #2 on: February 08, 2020, 04:00:02 pm »
There is no EEPROM and no config menu or settings to alter. This is what I do know:
The EPROM on the CPU board has the proper HP part# and the service manual has no comments regarding versions so suspect it is the right code.
The unit has a "IB SENSE" line that gets pulled low when the card is installed so the system knows if it has HP-IB or not.
Power supplies, RESET signal and interconnect continuity are all good, and it is a known-good interface card.
The data and control lines are connected directly to the CPU (6803).
A bit stumped.
Mark
« Reply #3 on: February 08, 2020, 07:18:31 pm »
FIXED IT! Someone had replaced one of the connectors on the MB to the CPU board and apparently destroyed two of the connections that control the HP-IB interface. (!)
Added two jumper wires and it works. Another unit saved!!!
Mark
Offline Tony_G
  • Checkout my old test gear channel (link in sig)
    • TGSoapbox
« Reply #4 on: February 08, 2020, 10:49:49 pm »
Nice - Congrats.
TonyG
