Author Topic: Hp 54100A software failure  (Read 3160 times)
Offline barneyTopic starter
« on: February 28, 2015, 08:34:49 pm »
Hi all,
I just purchased an HP 54100a digitizing oscilloscope with a faulty power supply and repaired it succesfully and all worked fine. After cleaning some dust around the cards i now have a software fault which reads `SOFTWARE ERROR!  Address error 0469BEH`
Can this be repaired? Would it be possible to get a backup of the eproms from Keysight maybe?
I am absolutely gutted and any help would be grately appreciated !
Offline Smith
Re: Hp 54100A software failure
« Reply #1 on: March 01, 2015, 06:56:44 am »
1. Are you 100% sure the PSU is still ok?
2. How did you remove the dust?
3. Have you tried reseating IC's / cards?
Software issues can have a lot of origins. Lots of times it's hardware related instead of eeprom / software related.
Maybe you can give some more info. You get an error, so I guess it boots? What does it do, and what doesnt?
Trying is the first step towards failure
« Reply #2 on: March 01, 2015, 11:32:55 am »
Yes the power supply is fine all rails are good. I removed the dust with brushes and wipes after removing the cards one by one very carefully. The cards were pretty clean so i didnt actually do anything with them it was mainly around the back near the fan. I have tried reseating all the boards but not the ICs. The interface board was not quite pushed in all the way on one side but only by a millimeter. (Could this of caused the fault?)
By the time the CRT warms up there is the error i mentioned above, it is highlighted and on top of a grid background. When i press the reset button (on the interface card) it seems to do a test screen with the option to abort (which doesnt do anything) and then back to the error screen. No other butons respond at all and no other text.
I will carry on trying to reseat things and look for any bad connections and so on later today
Thanks for your help.
« Last Edit: March 01, 2015, 11:38:13 am by barney »
Offline VK5RC
« Reply #3 on: March 01, 2015, 11:55:17 am »
Sorry I am no direct help but it may be worth a try at the yahoo group
https://groups.yahoo.com/neo/groups/hp_agilent_equipment/info
Does the scope respond to HPIB commands?
Offline Smith
« Reply #4 on: March 01, 2015, 02:17:14 pm »
You might want to take a look at the solder joint of the card connectors too.
