Author Topic: HP 54502A CRT to LCD convertion  (Read 467 times)
Offline JullRayTopic starter
« on: January 21, 2024, 06:17:31 pm »
Hello,
I would like to ask if HP 54502A display can be upgraded to LCD display.
Thank you for help/advice.
Regards.
Offline tom66
Re: HP 54502A CRT to LCD convertion
« Reply #1 on: January 22, 2024, 02:26:58 pm »
I had a 54501A a long time ago, gave it to a friend.  When I took it apart, it looked like the internal monitor was a Japanese-sourced unit (possibly Panasonic from memory).  It is very likely the signals to this monitor are just something like VGA, so it is probably possible to do so, but you would need to find an LCD panel that fit, some way to get the right supply voltage to it, and fit it into the case.
Offline Greybeard
« Reply #2 on: January 22, 2024, 03:03:20 pm »
