Author Topic: Tektronix 11401 dsy kernel failure  (Read 968 times)
Offline Johnny10Topic starter
« on: June 20, 2018, 06:09:20 pm »
I just purchased a Tektronix 11401 Oscilloscope with 2- 11A52 Plug-ins.
On start-up Self Test Error "dsy kernel failure" Second Line  "Exec Communication" is displayed on screen.
Since Kernel Diagnostics failed the Self-Tests will not run.
I have a copy of the 11401/11402 Service Reference
But I haven't found the meaning of this error other than the problem is on the A7 Display Controller Board since red LED is lit.
Anyone familiar with this issue?
Voltage on board is within limits.
Lithium batteries are 3.1 volts
« Last Edit: June 20, 2018, 06:23:11 pm by Johnny10 »
Tektronix TDS7104, DMM4050, HP 3561A, HP 35665, Tek 2465A, HP8903B, DSA602A, Tek 7854, 7834, HP3457A, Tek 575, 576, 577 Curve Tracers, Datron 4000, Datron 4000A, DOS4EVER uTracer, HP5335A, EIP534B 20GHz Frequency Counter, TrueTime Rubidium, Sencore LC102, Tek TG506, TG501, SG503, HP 8568B
Offline Xtremexp
Re: Tektronix 11401 dsy kernel failure
« Reply #1 on: August 15, 2024, 06:24:38 pm »
Did you manage to fix this issue? I am also having same error in my unit.
