Hi all,i have just recapped my scope psu,the service manual states to adjust the 5.2v supplies,if i remember it should be done using a 2 ohm load resistor on the 5.2v rail,i didnt do that with mine,i just reconnected the psu as is,at the time the 2x 1 ohm 25 watt resistors were on order,they have now arrived,although the scope seems to be working fine and calibrated ok and passes all self tests,the question is,how critical is the 5.2v rail setting,and should i go and check/adjust it as the scope seems fine,also what outputs should i see at the rear bnc calibrator outputs,thanks in advance,m3vuv
