Author Topic: HP 6114A Newbie Repair  (Read 3449 times)
Offline hifiguy99Topic starter
« on: January 29, 2021, 03:49:00 am »
Hi all,
I have an old HP 6114A. I have a few things I noticed that are wrong. I am inexperienced with vintage electronics and any input I would appreciate.
I have an imgur album here: https://imgur.com/a/RlH44oH
It seems I can't upload the pictures here directly as they are too big.
It buzzes quite loudly from the transformer. I assume this is typical of equipment this old, correct?.
The PCB is black. I mean not the entire PCB but I have no idea what would cause this exactly. The top underside panel is darkened in two spots. In does release some heat. Is this a major issue? See the picture:
You can see the distinction here:
As for any of the capacitors, should I replace any of them? I know tantalums go bad with age. I assume they are the yellow ones axial ones? Should I just leave it till one goes? None of the caps on the top side or mains side seem budging:
Lastly, if I halfway press the 2nd digit on the decade switch or if I switch voltages around too quickly, it jumps to a random voltage different than what is selected - usually higher. The meter shows it accurately though. Sometimes when normally switching voltages it will spike instantly and go back to normal.
Would a cleaning of the decade switch usually fix this? Example:
Thanks!
« Last Edit: January 29, 2021, 03:58:46 am by hifiguy99 »
Offline bob91343
Re: HP 6114A Newbie Repair
« Reply #1 on: January 29, 2021, 07:13:19 am »
That 10W resistor is clearly too small.  It's probably dissipating several Watts, like around 100 mA through it for nearly 80V drop.  Its paint job has boiled off onto the cover.  Look in the manual to see what the voltage across it should be and that will tell whether it is a bad design or a problem elsewhere.
As for the switch problem, it does appear a cleaning is in order.
The transformer buzz is due either to the overstress implied above, or that the bolts holding the laminations together have loosened.
The following users thanked this post: hifiguy99
Offline wn1fju
« Reply #2 on: January 29, 2021, 12:38:00 pm »
Your board doesn't look too bad to me.  I've attached a picture of my closely related HP 6115A power supply.  I wouldn't start replacing capacitors unless one (or more) is obviously spewing out electrolyte or voltage measurements show something is wrong.
You will need to remove the digit switches, dissect, clean, and reinstall.  See a pictorial in the eevBlog post:
https://www.eevblog.com/forum/testgear/hp-6114a-precision-power-supply-restoration/
Offline garrettm
« Reply #3 on: January 31, 2021, 02:22:21 am »
I would use an oscilloscope to check that the programming switches aren't causing large spikes / drops in the output voltage. One unit I had would jump around wildly until I cleaned the switches. Turns out the lubricant had dried up and was causing problems with the rotary contacts mating with the PCB pads when setting the voltage.
Also, you should clean the slide switch contacts, my analog display was acting goofy until those were properly cleaned too.
I've owned three of these power supplies, one of which was silent, the other two had noticeable transformer hum but one was much louder than the other. So the loud hum might just be an unlucky unit rather than indicating something is wrong.
I've made a imgur gallery with photos from my repair. Hopefully they can help you with yours.
https://imgur.com/a/sf8hrbu
« Last Edit: January 31, 2021, 02:35:03 am by garrettm »
The following users thanked this post: hifiguy99, TubeDoc, AlpineJoe
« Reply #4 on: February 02, 2021, 02:14:29 am »
Your are correct in that the resistor is small. I am lazy though and just cleaned off the paint off the surrounding components with some isopropyl alcohol and a Q-tip. The Q-tip could not remove the black paint caked on the motherboard though. I didn't try other solvents. Thanks anyways.
Tightening the bolts that hold the transformer do not help unfortunately.
I dissected the mechanical decade switch and used dexoIT gold on the contact plate and some Non-Stick Dry Film lubricant (with teflon) for the innards. It works like a charm now. Thanks for the help.
Good to know the hum is normalish. Thanks for the photos. I did spray down the meter switch with some Deoxit and then again with some of the lubricant as they do tend to get gunked up over the years, although my analog display was working fine.
I checked with a scope and the voltage changes look smooth now. Thanks for the tip.
Offline 6151kokodef
« Reply #5 on: October 22, 2021, 03:19:27 pm »
I got a 6115A which is pristine internally, but the 1V and 10V thumbwheel switch ranges would jump wildly to 9V (and 90V!!!) when switching between digits 2-3-4. I bit the bullet and dissected the thumbwheel switches like garrettm. It was quite gunked up as well. I cleaned them with alcohol and they work like new again.
As for the transformer hum I guess it's normal. Mains is 220V 50Hz where I am. My 6115A has very little hum but my HP 6228B and relatively modern HP 6632B hum like no tomorrow.
Offline Slavko
  • Country: ua
« Reply #6 on: November 14, 2021, 07:50:33 am »
I have two power supplies hp6114a and hp6115a and both had the same low frequency hum problem. It turned out that the reason was in the flat yellow capacitor 1mkf 250v. After replacing it with WIMA, the sound disappeared completely.
Offline AlpineJoe
« Reply #7 on: December 11, 2023, 11:41:46 pm »
Resurrecting an old thread, but I now own one of these and need to go through the thumbwheel switches.
From the photos, I see that I would trim the plastic that staked the PCB to the housing, then open and clean the wipers and PCB with gold plated traces.  What I don't see is any mention of what is done to re-stake the switch back together.
Do folks re-heat stake the posts?  Use 5 min epoxy?  Anything else?
Thanks for any tips.
Offline coppercone2
« Reply #8 on: December 11, 2023, 11:51:21 pm »
some ceramics they have buzz too. idk if its the new power grid situation or what, because the SLCC capacitors should not age. I replaced them with equal caps and there was still a buzz. I even added RFI filter to it, and it still buzzed.
for the switches, I wonder if its possible to build a compression plate thing with some standoffs /long bolts around the entire thing, so you don't need to use any fucking plastics technologies there
like really long thin threaded rods
« Last Edit: December 11, 2023, 11:54:26 pm by coppercone2 »
Offline garrettm
« Reply #9 on: December 12, 2023, 12:05:03 am »
Just wrap the re-assembled switch stack in kapton tape. That's what I did. This way you can clean the switches again--if needed--by simply removing the tape as opposed to possibly destroying the switch housings by trying to pry apart glued together plastic.
« Last Edit: December 12, 2023, 12:19:53 am by garrettm »
Offline coppercone2
« Reply #10 on: December 12, 2023, 12:11:05 am »
good idea, maybe give it 1 layer of self amalgamating tape over it because it wont have a bond failure like kapton
or a giant segment of heat shrink.
but what pissed me off about those switches is the spring loaded bits  :rant:
Offline AlpineJoe
« Reply #11 on: November 23, 2024, 05:48:36 am »
Finally decided to work on my 6114A, but already disassembled, cleaned the contacts, and reassembled and used the tiniest dot of uv cure epoxy in the front two corners and two more spots near the rear posts to hold it back in place before I read your reply.
Cleaned up the rest of the unit by blowing it out with compressed air and using a dry flux brush.  Time to power it back up and see what the next problem is.
« Last Edit: November 23, 2024, 11:34:34 pm by AlpineJoe »
Offline coppercone2
« Reply #12 on: November 23, 2024, 06:43:47 am »
probobly the switch lol :(
and I figured out how to hold it together finally, you can use a zip tie :-DD
Offline AlpineJoe
« Reply #13 on: November 23, 2024, 10:29:33 pm »
Powered it up last night and was amazed that  it pretty much works - except the output voltage is way off.  Dial up 1.00 and I get 1.37V.  10V setting and I get 13.7V.  I measured the voltages at the A2 board and the +16V is measuring 22.8V!  Okay, need to figure that out.
So just my luck, it ends up that R8A is open.  Why couldn't it have been one of the easier to replace parts?  15.82K 0.1% 1ppm.   Why would this fail. . . .
Sifted through my 1/4W resistors and found a combination that gets me close - installed it and my 16V reference is near 16V. Pushbutton settings give me close to what is expected.
Now the search for proper replacement.
Offline coppercone2
« Last Edit: November 23, 2024, 10:48:45 pm by coppercone2 »
Offline TimFox
« Reply #15 on: November 23, 2024, 11:07:15 pm »
In this type of power supply, the decade switches to program the output voltage form a variable resistor, as part of the DC feedback circuit.
Each resistor has a corresponding switch element that shorts it out, or not.
If a contact somewhere in the switch is dirty, when that contact is supposed to close (0 \$\Omega\$ for that part of the resistor string), the resulting resistance will be too high for the setting, and the output voltage (proportional to the total resistance of the string) will be too high.
Therefore, it is important to clean the switch contacts.
Offline AlpineJoe
« Reply #16 on: November 24, 2024, 06:46:09 am »
you can try  :-//
https://www.heisener.com/ProductDetail/Y000715K8200V0L
good luck
https://www.integrated-circuit.com/products-detail/Y000715K8200V0L/EIS-2897594.html
https://www.digikey.com/en/products/detail/stackpole-electronics-inc/RNCF1206TKW15K8/16206097
Here's an interesting source.  Was recommended this place from the HP test instrument Groups.io page.
https://www.texascomponents.com/store/VishayFoilResistors.asp
Looks like they can make custom resistors quickly.  Not sure the cost but the author didn't think it was exhorbitant.
HOLY SMOKES! They will make a custom resistor for about $13.
https://webdirect.texascomponents.com/ProductDetails.asp?ProductCode=VSMP%5F1206%5FCUSTOM%5F0%2E01
0.3W  0.2ppm  0.01%  (Any Custom Value from 250 to 25K ohms @ 0.01%)
or 1/2W for $16.23
https://webdirect.texascomponents.com/ProductDetails.asp?ProductCode=VSMP%5F2010%5FCUSTOM%5F0%2E01 VSMP 2010 Bulk Metal (Z) Foil Surface Mount Resistor; (aka Y1627) 0.5 W; 0.2 ppm/C TCR  0.01%
Amazing!
« Last Edit: November 24, 2024, 06:57:00 am by AlpineJoe »
Offline AlpineJoe
« Reply #17 on: November 27, 2024, 07:40:54 pm »
Unfortunately 'no minimum order' and the fact the form shows I can order 1 pc doesn't mean I can order only 1 pc.
I contacted TCC asking what the price with shipping would be and their reply was "The MOQ for the series is 5 pc. since is a very peculiar R value."
Not sure why my 'any custom value from 250 to 25K' is special.
Meanwhile I can find 5ppm parts of 15K and 820 ohm resistors in stock from Digikey for <$5 shipped, and really I just need to be in the range that A2R5 can adjust for so I could just use a single close value vs hitting 15.82K exactly.
Offline coppercone2
« Reply #18 on: November 27, 2024, 09:29:15 pm »
you can try  :-//
good luck
or 1/2W for $16.23
Amazing!
i think its cheaper lasers that make this possible
At some level, a tiny metal paper is just being passed through a laser printer
but it does not have leads on it. I guess you need a litle pCB with some thick copper leads
« Last Edit: November 27, 2024, 09:32:21 pm by coppercone2 »
Offline factory
« Reply #19 on: November 27, 2024, 09:56:06 pm »
