So I picked one of these up recently and its needs some TLC.
Symptom - No regulation, outputs ~530vdc regardless of controls.
http://www.keysight.com/en/pd-1000001527%3Aepsg%3Apro-pn-6209B/single-output-power-supply-0-320-vdc?&cc=US&lc=engTroubleshooting.
Checked all the voltage rails, all fine more or less where they should be. Checked test points 31, 33, 37, 38, 41, and the +16v rail. All good.
Checked voltages in table 5-2, again all good.
Check ESR/capacitance on all the large electros, no problems.
Looked over the theory of operation and checked the SCR control block, had the signals on test points 68, 67, 66. All looked more or less fine.
The "turn on control" seemed to be working. Upon power up the output is 0v for a few fractions of a second and then shoots to the moon, ~530v.
In the process of checking voltages...I could smell some "hot". With the voltages at hand, was not too keen to be touching things, but it seemed R49 (center of the schematic near the main rectification bridge) was the source. R81 & R54 are also in contact with R49, so it could have been them. This makes sense since C14 had 530v across it when powered.
Then as the manual recommends, I pulled CR35 and connected a DC supply across C14. Powered it back up and supplied C14 with 20vdc, output was 18.5v with no regulation. Output was ~1.5v minus whatever I fed in C14.
Followed Table 5-4 and shorted Q4 E-B, no change in the output. Still 1.5v less than what I fed in. Checked Q6 out of circuit, passed diode checks no shorts. VR3, same no shorts passes diode check.
I did a quick diode check on all the silicon between the output and CR35, and didn't find any issues. CR35 tested ok out of circuit, but since the turn on control works...I would thing at least CR35 or Q6 has to be working.
Then I looked around the feedback path and found R12 (center of the schematic by the A7 terminal) & R1 (center of the schematic in the constant voltage comparator) open and R13 measures 151k out of circuit and should be 36K (org, blu, org, gold). R10, the voltage set pot, also not so linear any more. Still within 1-100K buts in has some bad spots. Looks like someone kicked in the shaft, its a bit dicky as Dave would say...
So I have replacements coming for R12, R1, R13, & R10, the only issue I had was finding good replacements for R1 & R12. Digikey and mouser didn't carry any 2k 3W 5% 20ppm resistors available in small quantities, only 30ppm. Checked for 3-10W, still the same 20ppm seems impossible to find in small qty. Ordered the 30ppm anyway as I want to see if this guy comes to life. I assume this is not going to make a huge difference in the operation of the unit, but would prefer if I could stick with the original specs.
Anyone know where I can find a source for small quantities of suitable replacements or is it pointless?
Anything else that may be damaged from what I what I found so far?
