By the main cap, I presume you mean C9. The schematic says there should be 19V across it. I read 14.33V.
Where am I measuring current? On the output?
Thanks for your help.
Yes, I meant C9. The block drawing on page 4-1 of the manual you linked to shows 22V across C9 for the 6214A. Maybe they changed it in later versions. Either voltage will be fine. In any case, 14V3 is too low.
I'm not talking about using an external ammeter to measure current. With no load on the output, the ammeter in the power supply shouldn't show any current. However, if C14, C2, or CR14 were going bad, the ammeter might show a current flow. Actually, if they were pulling the C9 voltage down to 14V3 the ammeter will definitely show it and the regulator transistor should be getting very toasty!
Basically you have to start working through the troubleshooting procedures in the manual. They look pretty decent. When they give you a list of possible components, you have to figure out how to test that component. Hopefully, you can test it in-circuit. Sometimes you have to unsolder a lead to follow their procedures or test a component. That's a nuisance, but that's life.
Experience tells us that in an old piece of equipment, the electrolytic capacitors are often the first things to go. You've got C1, C2, C5, C9, C14 - not sure if I missed any. Some people would just change them all before spending any time diagnosing the unit. Even if they haven't failed, they're probably not meeting their original specs. Or they might fail tomorrow with possibly spectacular results. If the troubleshooting procedures point to one of them as possibly defective, you
really want to remove it and test it.
Changes in the equipment could be made to:
- reduce cost
- make it easier to manufacture
- replace unavailable parts
- fix bugs
- add features or improve performance
- improve safety
Most of the time, if a change is necessary or recommended the manual will say so. Otherwise, it's just to document the change so that the manual can be used with instruments of different ages. Actually, I see that one of the changes listed is to change the voltage across C9 from 22 down to 19. So you look at your serial number, read the change sheets, and figure out which value applies to the unit in front of you.
By the way, I noticed in one of your pictures that the 110 VAC leads for the fuse holder and the transformer primary are uninsulated. Unplug the supply and cover those, and any other bare 110 VAC leads (power switch maybe?) with electrical tape for safety's sake.
Ed
