So I picked up an HP 6236B a couple of months ago for around 60 USD from an online auction. It looked pretty grimy, but I figured it would clean up okay.
Here are the original listing photos.
After half a magic eraser, some elbow grease and a final scrub with a microfiber cloth we have a respectable little power supply. Surprisingly, the writing in marker on the side came off without any fuss. I also couldn't bear to look at the thumb tac jammed into the top right knob, so I dug through my spare HP parts and thankfully found a replacement. (I hope who ever pulled off the cap and stuck that thumb tack in there slips on a banana peel...)
After powering it up I noticed that the displays didn't work right. When the selector switch was set to 6v it read back the voltage and current decently enough. But when set to either +20v or -20v things were sketchy at best. If you held the knob just right, the display might work for a second or two.
Turns out there was some significant oxidation on the switch contacts. Holy mackerel Batman, look at that patina!
Grudgingly, I pulled the finicky bastard apart and used some baking soda paste and a tooth brush to clean the contacts, rinsed with distilled water, then applied some Deoxit to the contacts to hopefully keep them clean for the foreseeable future.
I apparently forgot to photograph the whole cleaning process... So here's the finished result after I'd put everything back together. Of note is the shinier silver contacts.
Now that the displays were working as the good folk at HP intended, I noticed the +20v meter flutters rapidly when I adjusted to about 8v... Oh great, right after I just reassembled everything, I need to open it up again.
What you are seeing is my lazy attempt to observe the rapid changes in the output voltage while slowly turning the 20v adjustment pot. Holy moly Batman, that's an oscillation!
Here's what adjusting the tracking knob for the -20v rail looks like. Notice the lack of oscillations while turning at the same leisurely pace. Clearly, we have a sick pot. I'm blaming that damn Coronavirus.
So here we go again.
Wait a minute... Is that--yup. It's a RIFA time bomb. I apparently missed it the first time I opened up the unit to clean the switch contacts.
Surprisingly, it actually looks okay. But I replaced it anyways--some random polypropylene Chinese job. Can't possibly be worse than the time bomb it replaced.
Well its time to bust out the goot wick and Kester 186 and get those pots outa there.
But wait, it’s time to break some stuff first. The rubber stand-offs near the pots had turned rock hard. As they say in Texas, there will be blood.
Meanwhile, I wicked off the excess solder, bent the pins vertical and then did some gymnastics getting the pots out.
Here they are. Hulking Clarostat wire-wound, single-turn units.
This guy looks like someone had opened it up already...
Well, let's see what the DMM shows. Yup, bad pot. And this is the one that had been tampered with. I don't know if it was worse than this and someone tried their hand at "fixing" it or what. All I know is that this little guy is going into the garbage can.
And here's what the other one looks like. Silky smooth. I'll put it in my parts bin in case I ever find a use for it.
A major gripe I have with the 6236B is the use of single turn pots. You get terrible resolution when adjusting with only a single turn, and its finicky too. So I decided to drop some 10 turn pots in. Its nice to gracefully dial in the correct voltage without overshooting by half a volt from twichy fingers. Saves delicate ICs that don't like to be overvolted.
Anywhoo, I figure some Bourns 3590S will do the job nicely: 10-turns, 50ppm/C, IP65 rated and cheap too. It's kind of nice to see something that isn't made in China. Gracias me amigos from across the border.
With those dropped in, I needed to replace the rubber spacers I broke earlier in my rampage. Luckily I had two rubber feet that were the same height. So I slapped them on and put everything back together.
After turning the PSU on, I quickly noticed I hooked up the pots wrong. Turns out I wired them for counter clockwise adjustment... oops. I had originally connected them such that pins 3 and 2 were shorted, but HP wants pins 1 and 3 shorted. So I pulled the blasted thing apart and rewired the pots. I didn't think to take photos of the fix while still under the berserk status ailment.
Putting everything back together for the umpteenth time, I was rewarded with clockwise adjusting knobs. Finally, the meter scales move in the same direction as the pots! However, the adjustment range for the 6v rail is out of tolerance: full scale is 7.3v--that’s off scale Batman! The +-20v rails at least stayed within the scale markings, clocking in at 24v.
I should point out that this problem existed before I put the new pots in.
That's all for today folks.
Tune in next time for some digging through the schematic and swapping out resistors to fix the full-scale output. Should be an easy fix. But keep your fingers crossed.
