Hello everyone! Long time lurker here
I had this one sitting here for awhile, figured I'd give it a shot.
I bought this power supply a while ago, for about 100USD + 50USD shipping from a guy here in Brazil, in the pictures he had in the ad it wasn't going up to 60v so I knew something was up.
Upon receipt, I tested it and yep, it wouldn't provide even a hundred mA and would slowly crawl to 40V.
Sooo I decided to give it a go last week, here are my findings:
Someone had a go on it before by the flux residues on the PCB;
Using the service manual troubleshooting guide, table 5-2 on page 5-9 here:
https://www.avionteq.com/Document/HP-Agilent-6267B-Operating-and-Service-Manual.pdfI already found a couple problems:
Step 4. Was getting a sinewave on TP 44, right after the diodes CR13 and CR14. Replace those four 1N5059 with four FR207 diodes (seemed to match the avg & peak current ratings) and checked the C12 capacitor, which was shot (measuring 2uF on the fluke 179 - was supposed to be 325uF). I bodged in a 330uF 16V and TP44 was normal again.
From here, the power supply could reach it's max output voltage (
) and I loaded it up using three Agilent 66332B, which take a maximum of 20V 5A each. It worked if I slowly increased the current from 5A to 12A, if I tried to go 0-12A in one step it would shut off the output and not come back until power cycled. If I did it in 1A steps I got it to 12A.
Step 5. TP45 , should read 4.8V +/- 10%, was near 6V. The only possible causes left was VR6 and VR7, which had flux residue. Turns out they were supposed to be a 2,37V diode from HP. I couldn't identify the code on the zener installed so I measured it to around 2.8V. MFG Part number: SZ 10939-2 / HP Part Number 1902-3002. I found one on ebay for 7USD + 32USD shipping (ouch), however seller only has one. Sent him a message asking if he has more.
Seeing that bad capacitor motivated me on replacing the eletrolytics on the main PCB, and since I will have to order stuff on digikey (40$ shipping), I will try to get a list of everything I need.
I saw there's a bunch of 2.4V zeners, not sure if they would work replacing a 2.37V...
I am taking note of the capacitors on the board and cross-checking with service manual to set up a Digikey order, will do the same for components which had flux residue just in case. Will also get some exact replacement 1N5059 diodes
From my readings, Nichicon VX are a good call, Vishay 118AHT excelent but costy. I'm lost on the 2.37V diode - messaged the ebay seller asking if he has two, but that 32$ shipping to Brazil...
High-res album:
https://imgur.com/a/zevp7UMAny help is appreciated!
Yours,
Luciano
