A1 provides the power supply, if the outputs are still incorrect with the load disconnected, then the problem is with the power supply section, or associated chassis mounted parts.
You will need a manual that matches the serial number prefix of your unit. Some parts & assemblies will be shared between the 651x to 654x oscillators, you may notice this in the board numbering, the 651B (647 prefix) manual gives 00652-66502 for the A1 board for example.
The output attenuator & front panel switching, will be where the most of the differences are between the models.
Edit: Looking at the 652A (prefix 1226A) on the web, the late version has the PSU section redesigned to use all silicon transistors and a couple of Op-amp ICs, this has part number is 00652-66504 for A1.
The older one (651B, 647 prefix) uses a mix of germanium & silicon transistors, hence why I mentioned looking for the correct manual.
