Hello,
I assembled an HP 66312A laboratory power supply from leftovers from the scrap. And has a CPU board in it from another 66312A.
I found a blown fuse F309 on the power board and replaced it. After that, it basically works correctly.
When calibrating, however, it is noticed that when calibrating the current of P2, when entering the measured value, the message "out of range" appears and the calibration is aborted.
Measure there with HP34401A approx. 1.8A,
the HP66312A shows about 2.2A
Without calibration, at least the externally measured current that is set is very accurate.
But the internal measurement is about 1.5 times too high.
Am I doing something wrong with the input when calibrating or is something wrong from the amplifier to the ADC?
