Author Topic: Salee Logic 8: Can someone please take a voltage reading here  (Read 1006 times)
Offline Psi
« on: November 03, 2018, 09:18:23 pm »
If anyone out there also has a Salee Logic 8 would it be too much to ask for a voltage reading here?
Trying to repair a faulty one.
Also if anyone can identify this IC that would be cool too.
It's a 5 ball BGA and probably a switch-mode voltage reg.
Marking looks like is  Line1= 31 Line2= K
Thanks a lot!
« Last Edit: November 03, 2018, 09:31:54 pm by Psi »
Online artag
Re: Salee Logic 8: Can someone please take a voltage reading here
« Reply #1 on: November 04, 2018, 02:33:55 pm »
I've got a pro 8. It's not quite the same, but it does appear to have something very similar - see ttt's pictures at
https://www.eevblog.com/forum/testgear/saleae-logic-pro-8-quick-teardown/
https://www.eevblog.com/forum/testgear/saleae-logic-pro-8-quick-teardown/?action=dlattach;attach=112275;image
Seems like a regulator towards bottom right, just below the flash chip. Mine has markings   Line1=33  Line2= .c
If you can work out which point is the equivalent, I'll measure that.
Also - have you contacted Saleae ? I don't know what their repair policy is but I've always found them incredibly helpful. They might just replace it for you.  Of course, that's not as satisfying as repairing it yourself :).
« Last Edit: November 04, 2018, 02:38:33 pm by artag »
Offline Psi
« Reply #2 on: November 05, 2018, 10:43:01 am »
Thanks, I'll have a look and see if i can figure out which reg matches the same reg on your one.
Yes, i have contacted them and they have been amazingly helpful. Salee is a great company.
but I might as well try to fix this old one though.
Online KL27x
« Reply #3 on: November 06, 2018, 03:18:05 am »
I have the original, probably the first few months they were available. I don't remember it being called an "eight" back then. The covers shows a picture of a chip, "logic," and the company website.
If you think it's the same model you have, I will see about getting it open. I thought I had my hex bit game in order, but these hex heads are smaller than anything I have.   :(
Offline Psi
« Reply #4 on: November 06, 2018, 05:49:17 am »
Thanks for everyone's help.
Salee had shipped me a replacement a few days ago (because they are just that awesome)
This morning the replacement arrived and they asked for the dead one back, which is totally understandable.
So there's no longer a need to attempt repair on the dead one.
Thanks again
