Author Topic: Hp 70911A option 005 (300MHz Amp)  (Read 744 times)
Offline K9DTVTopic starter
« on: January 03, 2025, 08:47:50 pm »
My 70911A started reporting errors the other day and tracked it down to the option 005 FM board.
The 300MHz amp on the board takes in a 300 MHz signal at 0 DBm and outputs at 0 DBm. But mine is outputting at -20 DBm.
These boards use 4-pin RF transistors and I have no idea what the part number is, can anyone help?
Thanks
Jim
P.s. I say transistor but know it's an IC Amp something like a MAR-4+, but have no idea.
« Last Edit: January 03, 2025, 09:05:22 pm by K9DTV »
Offline MathWizard
Re: Hp 70911A option 005 (300MHz Amp)
« Reply #1 on: January 04, 2025, 05:44:25 am »
For something that old, I'd email HPAK and ask them if any details on it, and if they recommend any modern replacements. But who/what/where in HPAC would get you results, IDK.
Online coppercone2
« Reply #2 on: January 04, 2025, 05:53:54 am »
I think it might be somewhat safe to put a amp in there so long you determine pinout and VCC
But are you saying the circuit is unity gain?
So that there is a unity gain MMIC in there, or there is a attenuator after it to bring it back to unity? Or typo?
« Last Edit: January 04, 2025, 06:16:10 am by coppercone2 »
« Reply #3 on: January 04, 2025, 07:12:44 am »
The 300 Mhz is used else where so it would be at least 3dbm down, so the amp would have 3dbm gaain, but this is a guess as it could be going many places.
« Reply #4 on: January 04, 2025, 07:15:26 am »
Sorry don't know HPAC.
« Reply #5 on: January 05, 2025, 04:00:19 am »
Got to thinking that they would use this part in other modules and I have the Clip to the 70900b. so I took a looked.
Sure enough found the follow part. 1826-1953 and said it was made by HP (28480) but more checking found it was made by Avantec inc and it's a msa-0335.
More checking shows that HP bought Avantec inc and this maybe a MAR-3SM.
http://www.hp.woodshot.com/hprfhelp/4_downld/products/rfics/msa0335.pdf
« Last Edit: January 05, 2025, 04:06:22 am by K9DTV »
« Reply #6 on: January 11, 2025, 11:13:40 pm »
Got the part in and the package was way to small, so I did some more digging.
Fist the input signal is split off and used else where and the output is also split off.
The transistor was a MSA01104 this crosses out to a MAV-11SM+ that is no longer made.
But they make a MAV-11BSM+, so I ordered some, I will let the board know if it works out or not.
Thanks for everyone's input.
Jim
Added link to a cross these type of RF transistors.
https://www.hb9afo.ch/articles/MMIC/mmics.pdf
« Last Edit: January 11, 2025, 11:16:55 pm by K9DTV »
The following users thanked this post: coppercone2
« Reply #7 on: January 15, 2025, 05:13:45 pm »
Parts showed up and now installed, All is well and works as it should.
Jim
The following users thanked this post: coromonadalix, coppercone2
