Electronics => Repair => Topic started by: K9DTV on January 03, 2025, 08:47:50 pm
Title: Hp 70911A option 005 (300MHz Amp)
Post by: K9DTV on January 03, 2025, 08:47:50 pm
My 70911A started reporting errors the other day and tracked it down to the option 005 FM board.
The 300MHz amp on the board takes in a 300 MHz signal at 0 DBm and outputs at 0 DBm. But mine is outputting at -20 DBm.
These boards use 4-pin RF transistors and I have no idea what the part number is, can anyone help?
Jim
P.s. I say transistor but know it's an IC Amp something like a MAR-4+, but have no idea.
Title: Re: Hp 70911A option 005 (300MHz Amp)
Post by: MathWizard on January 04, 2025, 05:44:25 am
For something that old, I'd email HPAK and ask them if any details on it, and if they recommend any modern replacements. But who/what/where in HPAC would get you results, IDK.
Post by: coppercone2 on January 04, 2025, 05:53:54 am
I think it might be somewhat safe to put a amp in there so long you determine pinout and VCC
But are you saying the circuit is unity gain?
So that there is a unity gain MMIC in there, or there is a attenuator after it to bring it back to unity? Or typo?
Post by: K9DTV on January 04, 2025, 07:12:44 am
The 300 Mhz is used else where so it would be at least 3dbm down, so the amp would have 3dbm gaain, but this is a guess as it could be going many places.
Post by: K9DTV on January 04, 2025, 07:15:26 am
Sorry don't know HPAC.
Post by: K9DTV on January 05, 2025, 04:00:19 am
Got to thinking that they would use this part in other modules and I have the Clip to the 70900b. so I took a looked.
Sure enough found the follow part. 1826-1953 and said it was made by HP (28480) but more checking found it was made by Avantec inc and it's a msa-0335.
More checking shows that HP bought Avantec inc and this maybe a MAR-3SM.
http://www.hp.woodshot.com/hprfhelp/4_downld/products/rfics/msa0335.pdf (http://www.hp.woodshot.com/hprfhelp/4_downld/products/rfics/msa0335.pdf)
