Author Topic: Need Help Programing an 93C46 EEPROM. I Can Read and Erase But Not Write.  (Read 10261 times)
Offline Chooch_FiestaTopic starter
Re: Need Help Programing an 93C46 EEPROM. I Can Read and Erase But Not Write.
« Reply #25 on: January 30, 2024, 09:46:29 pm »
True. It makes more sense to me it's X16 because the circuit on the alarm PCB has ORG and VCC tied together.
Offline DavidAlfa
« Reply #26 on: January 30, 2024, 09:52:36 pm »
So "you solved it". How about telling what the problem was to help others?
Offline Bud
« Reply #27 on: January 30, 2024, 10:26:17 pm »
93C46 is not on the list of supported ICs for CH341a. That programmer seems only supports 24 and 25 series ICs.
« Reply #28 on: January 31, 2024, 01:45:34 am »
They are supported using newer programming software.
Offline Bud
« Reply #29 on: January 31, 2024, 10:50:28 pm »
No software may help if the hardware has no support, things like voltages and timing. You can try buying a net new IC.
Offline wraper
  • Country: lv
« Reply #30 on: January 31, 2024, 11:20:20 pm »
It supports 93C46 with adapter. All CH341A programmer is is a CH341A universal USB converter IC on a board.
Voltage is absolutely nonsensical argument, like one 5V is different from other 5V. Timing argument does not make much sense either.
« Last Edit: January 31, 2024, 11:30:48 pm by wraper »
Offline Bud
« Reply #31 on: February 02, 2024, 02:56:40 am »
That was a generic statement to illustrate the point.  Voltage could have been 3.3V vs 5V, i did not check the datasheet for that particular IC.
Offline Katuga
Did you successfully program a 93C46 16-bit Serial EEPROM using the Ch341a programmer? TIA
