Sometimes the circlip on the screw on the inside of the cover gets lost, in which case you can unscrew the center screw entirely. If that happens, take it out then use a small flat bladed screw driver to carefully pry at the front corners of the cover. The cover has to slide back a centimeter or so before it will lift clear.
It can get tight if the case has been banged up.
