Author Topic: HP 8510 VNA interconnect cables pinout  (Read 930 times)
Offline wojciechTopic starter
« on: September 20, 2021, 04:41:44 pm »
Does anyone of happy owners of the 8510 VNA would be so kind and helpful and check by ohm meter what is the pinout of 08510-60101 (IF-Display) and 08510-60102 (S-parameter test set) interconnect cables? (if this is 1:1 i.e. pin1->pin1, pin2->pin2 etc or maybe some different pinout...) I own both display and detector units but unfortunately without any interconnect cables. 08510-60101 cable is pure digital so I suppose it should be relatively easy to make it by myself (90$ is just ridiculous price for such cable). 08510-60102 cable is much more complicated (mixed signal DSUB) since it consists also RF coax lines but finally I think I could eventually also make it by myself since mixed signal DSUB connectors are available on the market.
I would be very, very grateful if someone could send me that information. I couldn't find it anywhere. I also read that there was never service manual (at component level) published for that 8510 VNA so I don't think there is any other place where I could find that. I was aslo asking for that information one of the test equipment sellers, unfortunately without success (probably even know why)
Best regards,
Wojciech
Offline simmconn
Re: HP 8510 VNA interconnect cables pinout
« Reply #1 on: September 21, 2021, 06:26:49 am »
The IF-Display cable is one-to-one. The CLIP of the 8510A/B IF, 85101A display and test set boxes are available, in both hard copy and  pdf. I’ve not seen a CLIP for the 85101C display box.
« Reply #2 on: September 21, 2021, 03:14:26 pm »
Hi simmconn,
Thanks a lot for information about IF-Display cable. That's great! Would you be also so kind and could check 08510-60102 cable? :)
Sorry for my not complete understanding - by "CLIP" you mean "component level service manual"? I was looking for that but I couldn't find it anywhere (google, ebay). I only have these from great ko4bb site. There is however no service manual with component level schematics...
Best regards
Wojciech
Online MarkL
« Reply #3 on: September 22, 2021, 05:03:15 pm »
Artek Manuals looks like it has the full set of 8510A manuals for USD$20:
  http://artekmanuals.com/manuals/hp-manuals/
You can ask them before purchasing if it's unclear what you need is included.
They have excellent quality scans.  No relation;  just a satisfied customer.
« Reply #4 on: September 23, 2021, 01:23:07 pm »
Hi MarkL,
Thanks a lot for additional information. Looks like Artek Manuals has indeed 8510A full manual, but actually I have 8510B version which was released 3 years after 8510A so I will probably search for 8510B version (probably only hard copy version is nowadays available, but I will need to make sure there are component level schematics).
BTW SM from ko4bb site which I previously mentioned is actually "HP 8510C On Site Service Manual" so probably that's the reason why there is no component level schematics.
Best regards,
Wojciech
