Author Topic: HP 8566B CRT focus problem  (Read 276 times)
Offline jonsikulTopic starter
  • Country: is
« on: April 24, 2024, 07:04:41 pm »
As the title suggests, I am having a problem focusing the CRT on my HP 8566B. When adjusting the focus on the front panel it is like I just need a half a rotation more and then it would focus but the focus screw doesn't allow for that.
Is the CRT just weak?
I just got this machine from an auction without any description on how it works, so I am turning it on for the first time.
Offline Greybeard
Re: HP 8566B CRT focus problem
« Reply #1 on: April 25, 2024, 07:15:19 am »
Check all voltages at the CRT.
Check resistance of all resistors and potentiometer in the focus resistor chain and check solder joints.
May be this helps:
https://www.jvgavila.com/hp8566a.htm
« Last Edit: April 25, 2024, 09:23:38 am by Greybeard »
