Hi Glen
Have you found the solution to your issue?
I just acquired a 8566B / 85662A display with the same issue you described. On my unit, the IF section -15V supply is apparently being loaded (down to -2 V, and the LED light is very dim. I substituted in a good A1A6 board (has the -15V supply), and it made no difference. So, I assume that the A1A6 supply board is okay, and the load must be coming from another board, perhaps from a shorted tantalum capacitor or zener diode.
I will be substituting other known good boards to try to isolate the load, but would appreciate helpful guidance from anyone who knows these display units.
Joe, KN5U
