Electronics => Repair => Topic started by: tonycox01 on January 14, 2020, 10:06:54 am
Title: HP 8566B spectrum analyzer trace flicker/glitching
Post by: tonycox01 on January 14, 2020, 10:06:54 am
I recently got hold of an HP 8566B SA which largely seems to be working OK apart from a random flicker/glitching of the trace display. The trace appears to break down in to a flurry of horizontal lines at random intervals and positions. I've trawled for similar issues with the 8556B but not come across anything so I thought I would ask a question here before diving in to serious troubleshooting - just in case anybody has seen a similar problem or has any suggestions about where to focus my troubleshooting efforts.
I have created a short video that demonstrates the issue (this brief capture was from the self calibration routine).
https://youtu.be/LvoDBJFQfnM
thanks in advance for you help/suggestions.
Tony
Title: Re: HP 8566B spectrum analyzer trace flicker/glitching
Post by: jfphp on January 14, 2020, 10:11:20 am
I will try with the power supplies (ripple) mainly those going to the display board.
Post by: tagchen on January 14, 2020, 10:28:37 am
in this old measurement tools check power supply caps, mostly higher voltage (400-450V) are the problem.
this problem can be keramic caps for digital chips (cpu boards or so)
have you picture from inside?
installing retrofit document can little help.
[attach=1]
service and repair manual to big to post, find in keysight page
Part Number: 08566-90042 (Dec84). This manual is provided for information only. The 8566B and 8568B are no longer sold by Keysight. Note: the file size is 36.37 MB.
Post by: tonycox01 on January 14, 2020, 01:40:35 pm
Thanks - no picture yet but I'll try and get some.
I'll start with the caps on the power supplies and see where that goes.
cheers
Tony
Post by: Johnny10 on January 14, 2020, 02:39:10 pm
I might check for input power line noise.
