Author Topic: Power supply outputs random voltage  (Read 439 times)
Offline ulianoTopic starter
« on: September 28, 2022, 11:57:36 am »
Suddenly (after maybe some year of NON use) this old PSU got crazy
Often, but non always, more likely on channel 2, the voltage under load is less than programmed even if the drained current is far less than the preset limit.
I have no idea where to start looking to investigate this problem.
Some explicative pics.
« Last Edit: September 28, 2022, 01:44:10 pm by uliano »
Online wraper
  • Country: lv
Re: Power supply outputs random votage
« Reply #1 on: September 28, 2022, 12:12:22 pm »
Your electronic load could be oscillating. Try adding say 1000uF cap to PSU output.
« Last Edit: September 28, 2022, 03:37:16 pm by wraper »
« Reply #2 on: September 28, 2022, 01:37:16 pm »
I didn't think it was the case as the problem showed up with a real (and very small) load, however
What is worst is that it doesn't even need a load
Online Ice-Tea
    • Freelance Hardware Engineer
Re: Power supply outputs random voltage
« Reply #3 on: September 28, 2022, 02:44:00 pm »
If memory serves (and that's by no means a guarantee), the polarity protection diode on the outputs is a weak point in these supplies. Wouldn't hurt to check. YMMV, obviously, but it doesn't hurt to check...
The following users thanked this post: uliano
