Author Topic: HP 8594E ntsc setting  (Read 1222 times)
Offline DaxxinTopic starter
« on: March 26, 2017, 03:05:00 pm »
Swapped the crt from an 8593 that supports only ntsc my configuration is set to NRM PAL i view only garbled things
someone has this scope can pls post picture about CONFIG steps to push correct buttons until i can restore NTSC.
thanks
Online MarkL
Re: HP 8594E ntsc setting
« Reply #1 on: March 26, 2017, 03:50:42 pm »
This is from an 8495E, but it should be the same:
First, press the CONFIG button.
Then, press side button #6 twice to get to the SYNC menu.
Then:
Press side button #2 to toggle between NRM and NTSC
  -or-
Press side button #3 for DEFAULT SYNC
  -or-
Press side button #4 to toggle between NRM and PAL
You could also try plugging a monitor into the back to see what you're doing.
« Reply #2 on: March 26, 2017, 07:41:53 pm »
Thanks it works , i tried to make VI in labview to do that but unsuccesfil  >:(
