Hi
got a 8595E off Ebay recently , showing two issues.
first the keyboard was not responsive at all, the sweep refreshes every minute of so. after some measurement on the YIG , it appeared to be dead.
Installed a replacement from a 8594E and after a factory cal reload the operation was back to normal.
the second issue is the same as described above. Spot on below 2.9GHZ but no signal in the high band. After taking the YTF filter appart guess what?
yeah... misaligned spheres again.
I managed to realign two of them but infortunately the one on the high band side had snapped off it's rod and my attempt to glue it back into position was a complete failure
My guess is that when the sphere is detuned to the point it touches the loop it snaps off shortly after
I thing the analyzer was used in low band until the YTO failed then was decommissionned.
the rods are made of glass apparently so be very careful when touching them.
I wonder what kind of glue they used in the first place ?
Some interesting info on wire bonding on this page :
https://www.qsl.net/ct1dmk/wbond_ex.htmlsome shops offer YIG rebuilding as well but the prices are... hum...
EDIT : surprisingly enough the 8595E passed all self calibrations and confidence test with a dead YTF. Weird
