Author Topic: HP 8601a substitution for unobtanium IC  (Read 1701 times)
Offline neilTopic starter
« on: August 21, 2019, 03:22:53 pm »
Moving along with the HP8601a sweeper (seized attenuator shaft now resolved), it appears that the IC used as the loop amp in the A3 module is deceased. I tried reseating it several times, but no joy. I gather that these are unobtainium, so am wondering about a modern substitute. This sweeper would be for non-critical hobby use.
The amp (labelled "E1" on the schematic) sits in a PLL loop, between a mixer and a divider chain (which starts with a 2.2uF blocking capacitor). It has a +20v power line and signals in the 0.1 to 110 Mhz range. The input is shown as -20 dBm and output at least 2 dBm.
I wonder if I can substitute a modern chip, perhaps a video amp of some sort on a small daughter board, with appropriate voltage-shifting circuitry as needed? Any suggestions for favorite chips?
« Last Edit: August 21, 2019, 03:26:05 pm by neil »
Offline fzabkar
IRe: HP 8601a substitution for unobtanium IC
« Reply #1 on: August 21, 2019, 10:14:54 pm »
I couldn't find the part (1820-0151) in the cross references:
https://www.sphere.bc.ca/download/hp_xref-free.pdf
However, here is something along the lines that you propose as an alternative solution:
https://f6aoj.ao-journal.com/cariboost_files/hp_20hybrid.pdf
« Reply #2 on: August 21, 2019, 10:59:39 pm »
1820-0149 is referenced as well. See: https://susumu-oiso.blog.so-net.ne.jp/2017-04-05 for a substitute. Looks like they used a standard MMIC as a replacement. You will need to use google translate.
Offline retrolefty
« Reply #3 on: August 21, 2019, 11:20:09 pm »
I too own this sweeper and when obtained used had like half output power but otherwise worked fine. Traced with a scope that A3 was not putting out full gain. I added a Mini-circuits standard MMIC  before the input to the hybrid. I just wired it up dead bug style and it seems to work just fine. It's not a lab quality piece, but extremely useful for sweeping filters. The step attenuator is very nice mechanically and electrically.
« Last Edit: August 21, 2019, 11:27:52 pm by retrolefty »
« Reply #4 on: August 22, 2019, 03:08:11 am »
Thanks for all comments.
It certainly looks like a simple mmic amp would be the first thing to try. My first thought was something from Minicircuits, but I don't know if they do small orders. However, Mouser lists a BGA2874 with 31 dB gain over a DC-750 Mhz range, and at the cost of 41 cents in single-unit quantities, it's hard to turn down.
Offline Tony_G
  • Checkout my old test gear channel (link in sig)
    • TGSoapbox
« Reply #5 on: August 22, 2019, 06:33:07 am »
Minicircuits will do small orders. Sometimes they even have dev boards for the part if you want to use one.
TonyG
Offline djsb
« Reply #6 on: April 09, 2021, 11:44:54 am »
Did you get this sorted? I might want to buy one of these units. Thanks.
David.
Hertfordshire, UK
University Electronics Technician, London, PIC16/18, CCS PCM C, Arduino UNO, NANO,ESP32, KiCad V8+, Altium Designer 21.4.1, Alibre Design Expert 28 & FreeCAD beginner. LPKF S103,S62 PCB router Operator, Electronics instructor. Credited KiCad French to English translator
