Author Topic: HP 8640B power supply problem  (Read 789 times)
Offline sweatybettyTopic starter
« on: August 05, 2021, 04:52:05 pm »
Hello all!
Picked up a 8640b last week. Not getting any output nor am I getting +44V. I think I have that part figured out.
While looking through the FSM, I found a term I have never seen before and am hoping someone can enlighten me to the meaning or point me in the right direction. The term is "crowbar"
It is shown on the schematic and in the troubleshooting section as well.
Appreciate the help!
Offline TimFox
Re: HP 8640B power supply problem
« Reply #1 on: August 05, 2021, 05:09:40 pm »
A crowbar is a fast-acting circuit that shorts the output should the voltage exceed a threshold, to protect the load or regulator.  It’s analogous to throwing a crowbar across the third rail on the subway.
« Reply #2 on: August 09, 2021, 02:45:37 pm »
Thank you Tim.
I found more info after changing search words around :-+
