Battery is 3.6V NICAD. Size is about the same as AA battery except it's a bit shorter and has lead on both side. If you open the top panel, there is a section with aluminum shield with 3 RF connectors. Unscrew one screw and it will open. One of the card has that battery.
Instead of Nicad, I used NiMH battery. Yes, charging parameters are different but it's so low current, I never had any issues.
I'm not opening mine to take pictures, but once you look, it's quite obvious.
Remember to lift from your knees, not the waist.
