I just purchased a HP 8648C signal generator on eBay. The unit passes self test, and the display of frequency and output level responds to the front panel input. When I turn on the RF output, I can hear a relay click. But no signal comes out of the RF output. I checked it with a scope, as well as with a spectrum analyzer.
I'm not sure what exactly the self test checks. Would it report an error, if no RF signal is generated by the internal unit at all? Is the problem likely at the mechanical attenuator? Any suggestion is appreciated.
Thanks,
Jerry
