On inspecting a newly acquired above power supply, the input line capacitors indicate a need to be changed, the 100n X2 Rifa no problem with a replacement, but the 2 smaller 1n0 are Y2 rated, are not easy to find, any problems seen in replacing these with X2 rated items. Thanks for any input, Alan.
