So here's where things stand. And I don't think they look good.
I tested out the -5v supply, and it is working ok. Also tested the others.
I opened the A12 frequency doubler, and I noticed a resistor that had been getting hot. Color bands faded, and discoloration on the board under it.
There is a 723 regulator on that board with an external pass transistor, and the 22 Ohm resistor in the collector lead is the one getting hot. So something on the doubler board is dragging down the power supply, and when it acts up, a red led lights on the board. Sometimes, after a little time, the led will go out and the voltages will rise, and the doubler works again.
That makes me think that the led is maybe a current limit alert?
But, also, when I looked at similar auctions on Ebay, most describe some kind of issue with the doubler, or it's frequency range.
So, this must be a common fault, and it's odd that HP did not release any service information on this board.
What is so special about it that it can't be repaired, or a schematic produced?
I doubt I have the skill to try to reverse engineer that board to figure out where the current draw is coming from.
I do notice that I have a 1995 board, and it is newer than others that I saw pictures of.
It has 2 Actel FPGA's, and a bunch of DAC's, and the RF section, but not much else.
So unless I can get some information from a similar device, I guess I have a doorstop.
I have not been able to locate a board for sale to replace it with.
