Does anyone have any information please on two circuit protection devices on the HP 8662A power input, which aren’t shown on the schematic?
The first, presumably an NTC thermistor for inrush current, is in series with the primary of the oven transformer. In fact it and its leads form the connection between the transformer terminal and the 240V neutral output of the voltage selector switch. It’s a disc about 10mm diameter, tightly enclosed in black heatshrink, solid ?nickel leads with clear insulation. It’s 33 ohms out of circuit, room temperature.
The second sits between the live output of the filter and the switched 240V neutral from the voltage selector switch. So clearly not a thermistor – maybe a MOV for spike protection? Very similar appearance to the first, but the diameter is around 20mm. Out of circuit it reads as open circuit on the meter, but presumably it does its stuff only when much higher voltages are applied.
I ask because I’m having to repair the power input section of my new HP 8662A after a corner smash in transit (two broken fuse holders (main and oven), a smashed main fuse just holding on by its wire, several distorted small covers and panels). HPs legendary build quality, so evident everywhere else in the instrument, seems to have deserted them in this unglamorous corner - it’s a dreadful bird’s nest of mains wiring running between the rear panel and other sub-panels in every possible direction, several exposed terminals sitting just millimetres from various bits of the case and sub panels, and all crammed into too small a space. I did all the replacements and repairs, powered up and everything seemed happy. But I’d forgotten to fit the small internal metal cover that hides the mess of wiring behind the power panel. This cover was quite a tight fit due I think to a bit of residual distortion of the geometry around that corner, but in it went and I checked for no trapped wires or shorts. Or so I thought – on the next power–up I got a flash/bang from somewhere behind the power panel, a little smoke and the house circuit breaker tripped leaving both fuses intact. Investigations continue, but I want to be sure of what I’m dealing with for these two devices, and also to check they weren’t destroyed (they both still look perfect but I don’t want to disturb their heatshrinks if I don’t need to.
This is a UK-spec 240V operation unit, so I wonder if there was some official mod for the UK market that isn’t on the schematics I’ve seen?
Thanks in advance for any help, and apologies if they're mentioned somewhere else in the full manual, which I don't yet have a copy of.
