I have a 8753C network analyzer including the test set. The unit looks almost like brand-new, and it works fine.
However, it has a strange behaviour: when it is turned on for a while (approx. 10min or so), then the message "low air flow! replace fan filter" appears. However, my unit does not have a fan filter. I checked the schematics and found out that the low air flow condition is detected by the temperature difference measured by two sensors. I checked the heatsink temperature, but it was quite good I think (around hand-warm, which is okay I guess). I thought the low air flow message could have something to do with the temperature sensors.
Further, there is another problem: if the analyzer is turned on while it is cold (room temperature), no problems at all. However, if I let it run for a while, then turn it off, and turn it back on again while it is still hot inside, it reports 'no phase lock' until PRESET is pressed. From there on, it works still fine.
I wonder where I should start looking for the solution to this strange problem. Every performance test is PASS, the supply voltages are fine, and the heat sink is not really hot. What could be the case?
