Put in a plug in socket so you can try different DIP OP amps if necessary
Usually you can find a DIP that works in place of the can type.
Saves a lot of aggravation if you have to switch. Also easier to install.
Sometimes a lot of different OP AMPS will work especially if it is just a DC volt comparison
OP AMPS are not perfect on their input, they need adjustment, sometimes even the same part number amp will vary, even those in the same batch.
Sometimes a cheaper amp will work just fine, HP has a habit of using the most expensive parts.
