I fixed a similar one recently. This is what I would do:
Be careful probing around inside -- a slipped probe can cause more damage. It is most likely that the power stage is damaged.
See if S2A (range) makes any difference.
Is the output 0 because it is shorted or because the supply is providing no current ?
Check if R2 (the current sensing resistor) isn't open circuit. It's a large one (5 W) -- it won't be shorted, but you won't be able to measure its resistance easily (< 0.2 ohm). If you don't have a replacement, you can just short it temporarily -- but then don't short the output, and only turn on the supply when the voltage setting is 0 -- you can then raise it, but each time you turn on the supply, ensure that the V setting is 0 (because the R2 also protects the supply from inrush currents in C3).
Check TP2 vs. GND (the -ve output terminal). Should be about 20-26 V. If it is low V, then perhaps the diodes in the bridge rectifier are shorted -- nearly any diode will work, but 1N4004 or 1N5404 would be good replacements. With the PCU off, short C2 (big cap) with a 1-100 ohm R until the V is 0. If you don't have one, R1 in the schematic will discharge C2 eventually (check with DVM until it goes << 1 V.) Then check each diode individually -- you might find a shorted one.
The 4 pass transistors are soldered to the board and hard to remove :-( . Either they are bad, or the control circuit is bad. You can short Q2 base to the +ve VOUT -- and see if the current limit warning disappears.
