Author Topic: HP Agilent E4418B Power Meter keypad flex circuit E4418-20007 needed  (Read 3215 times)
Offline Ordinaryman1971Topic starter
Hi guys, i need an HP Agilent E4418B Power Meter keypad flex circuit E4418-20007
Mine stopped working.
Offline kada
  • Country: ie
Re: HP Agilent E4418B Power Meter keypad flex circuit E4418-20007 needed
« Reply #1 on: March 03, 2016, 02:39:52 pm »
Hello,
I also need this one.
My flex keypad stopped working too.
The new part number is E4418-66502 (taken from Keysight site).
Offline kada
  • Country: ie
« Reply #2 on: March 09, 2016, 02:18:08 pm »
After receiving $183 quote from Keysight for flex keypad I definitely decided to do it myself.
First of all I bought the thinnest push-buttons I was able to find. It is only 0.8mm thin.
I decided to mill 1.5mm PCB on my CNC-engraver and after it to reduce thickness down to 0.7mm by back side milling.
PCB Milling
Results:
I also glued rubber circles taken from old remote controller to rubber keypad pushers for better force transfer to push-buttons.
I was not satisfied with result since after keyboard assembly some push-button was pressed and did not released due to the increased length of rubber keypad pushers and push-buttons thickness.
So I decided to cut pushers of rubber keypad and re-glue the rubber circles.
Now all keys works excellent with little more pressing force comparing to original keyboard.
In addition there is a tactile effect which improved ergonomics of the keyboard.
I also included Altium Designer 15 project of the PCB for those who decide to do it.
