Ok received this morning. TME are pretty good. That's the first order that I have done through them and it was very smooth.
Binding posts are pretty much exactly the same as the Agilent ones with the following differences:
1. They are a slightly lighter grey.
2. They are ever so slightly larger so I had to run round the inside of the front panel with a deburring tool to get them in.
3. Plastic is matte rather than gloss.
4. Main retaining nuts are metal instead of plastic.
On this basis I decided to replace them all for consistency. Took about an hour in total and required a 4mm bit on my 55W Weller iron. Don't attempt this with anything less!
I did notice inside that HP didn't install the shaft retaining nuts on the original binding posts which is what eventually lead to their destruction as the main shafts pulled through on two of them. Naughty naughty HP. Boo hiss.
Anyway, all sorted and looking good as new. Thanks again to 2N3055
