had the same issue with a cannon once,ended up using a shringe with some plastic tubing to shrynge hot water into the small nipple where the ink tank passed ink into the print head,did it about 6 or 7 times untill clear water came out of the ink nozzles ,dried it out refited the ink cartrige and it was fine.
