I am trying to repair a sega sg-1000 II which has a noisy modulator. It is not the inherently low quality of the RF signal, because another sg-1000 II on the same TV, with the same modulator provides a much better signal.
I attach some photos of such modulator. I tried tuning the variable inductor and changing the electrolitic caps, but that made no difference. I also tried to slightly straighten the vertical wire wound inductor, which appears to have become loose from the epoxy, but that gave no improvements.
Are there any common faults of RF modulators worth checking?
(I know I can just buffer the composite video and audio, but I'd like to keep it original).
