Hello feedback.loop, I like your videos, thay are very instructive! I learned a lot...
I'm trying to repair a 2nd generation 'blue screen' axiom 49/61 board...
It is mounting an C8051F34 microcontroller, this board is very different from 1st gen (?) TCM809 ...
It looks like reset line is permanently pulled up through a resistor, so probably reset is done by software.. tried to pull it down briefly but no luck... Maybe I should reflash it, but usb is not functioning at all...
Do you have any repair experience on this board ? Any hint on how to flash using direct serial connect ?
Thanks for help
