Author Topic: Power Designs 2005A Oven Repair  (Read 1156 times)
Offline BarryBreauxTopic starter
  • Electrical Engr, Control Systems Engr, Retired
« on: February 18, 2023, 08:48:00 pm »
Does anyone on here have any experience repairing one of the Power Designs Ovens?
So I found that all the components in the oven have been overheated to the point that the casing around the resistors are cracked and fallen off. I suspect that the thermostat switch was not functioning correctly.
Regards,
Barry Breaux
« Last Edit: February 20, 2023, 03:24:15 am by BarryBreaux »
Barry Breaux
Offline max.wwwang
Re: Power Designs 2005 Oven Repair
« Reply #1 on: February 19, 2023, 06:38:59 am »
Did you take any photo of the crime scene?
Neutral | grounded
Re: Power Designs 2005A Oven Repair
« Reply #2 on: February 20, 2023, 01:22:34 am »
Yes sir!
« Last Edit: February 20, 2023, 03:26:35 am by BarryBreaux »
Barry Breaux
« Reply #3 on: February 20, 2023, 01:24:04 am »
The other side.
« Last Edit: February 20, 2023, 03:25:39 am by BarryBreaux »
Barry Breaux
« Reply #4 on: February 20, 2023, 01:31:49 am »
The bracket that holds the thermostat broke, I think this is why it cooked my components.
« Last Edit: February 20, 2023, 03:26:09 am by BarryBreaux »
Barry Breaux
Offline alm
« Reply #5 on: February 20, 2023, 01:34:52 am »
Thanks for the pictures. Those are definitely some deep-fried resistors!
Offline Stray Electron
« Reply #6 on: February 20, 2023, 01:44:46 am »
  There is at least one other thread on this forum about a tear down or a repair of the PD meters.  I think only the PD meters with the stepped dials use the ovenized temp reference.  I'm also fairly sure that there is an operators and a service manual online for the 2005 model.
The following users thanked this post: BarryBreaux
« Reply #7 on: February 20, 2023, 03:06:54 am »
Those toasted components all still worked somewhat. Off spec, but the power supply still worked. The controls were off by 40 mv. I also found the filter capacitor to be bad. This thing is solid!
« Last Edit: February 20, 2023, 03:24:47 am by BarryBreaux »
Barry Breaux
« Reply #8 on: February 20, 2023, 03:00:01 pm »
I found several users who have rebuilt their oven. One user was proposing using a micro controller to improve on the temperature control. I am very interested in knowing his final design! Of course I would like to hear any success stories!
Barry Breaux
Offline exe
  • self-educated hobbyist
« Reply #9 on: February 20, 2023, 04:13:40 pm »
Yeay, I'm curious too. I've a PD power supply, and those thermostat clicks are annoying. It shouldn't be too hard to implement it (I guess all it takes an opamp and a thermistor, but I'm lazy).
Offline floobydust
« Reply #10 on: February 20, 2023, 06:40:30 pm »
Power Designs 2005A schematic manual https://www.barbouri.com/2018/01/13/power-designs-2005a-precision-power-source/
It looks like the TIC47 SCR 200V 0.3A which controls the heater fails short?
Offline max.wwwang
« Reply #11 on: February 21, 2023, 04:29:27 am »
I have now seen truly cooked components!
Neutral | grounded
