Hi -
First post to the forums, and I'm a relative beginner to analog electronics. I'm trying to repair an HP E3610 from around 1992. When I received the power supply, the AC fuse was blown, and on opening the cover I found several of the electrolytics were leaking. I replaced all 5 of the large electrolytics and thoroughly degreased the board. There were no obvious signs of other damage. The power supply is mostly functioning, but isn't stable.
On power-on, with the voltage and current knobs full counter clockwise, the voltage reads around -10 volts, and slowly over 5-10 minutes will creep up to +1-2 volts, then settle at around 0.25 volts. The CV and CC indicators are both on, but eventually the CC indicator goes off. Any change of temperature, like a draft, will cause the voltage to drift upwards. Both the voltage and current adjust knobs will change the settings, but the displayed voltage is higher than measured with a DMM at the output. I'm waiting for a couple power resistors to arrive before checking out the current settings.
The display voltage at TP9 & TP10 is 4.98 V.
The reference voltage section reads: TP1 12.14 V, TP2 6.92 V, TP8 -11.94 volts using +output/TP6 as reference. CREF/TP7 tracks the CC current pot from -0.21 to -6.64.
With the CC current set to 3.0 amps, 1 V on the DMM reads 1.49 V in the display, 2 V on the DMM reads 5.21 V, 8 V reads 11.51 V.
The voltage at the bridge rectifiers is CR13 8.55V, CR9 37.33V, and CR2 16.86V (US 120V power).
I have the 2000 Schematics, but it has some slightly different components than I see on the board.
Any advice before I start messing around with the innards ?
Thanks,
Gary
