Assuming all the switches in the back of the unit are in the up (master, local) position and nothing is inserted in the terminals...
See attached (open in new window, zoom in) for a highlighting of part of the voltage feedback loop and
this partial simulation (and attached screenshot).
Background before discussion below:All the op amps are powered via +15V/GND/-12V isolated supply (second transformer winding) with GND attached at the +OUTPUT terminal! Note the purple circles.
Q:Why reference GND to +OUTPUT?
A:So a voltage can drive the MOSFET gate(s) WRT its source(s) without considering the currently set voltage between +OUTPUT and -OUTPUT.
You might think this is a variable negative power supply, ie. +OUTPUT=0V and -OUTPUT=0..-20V
Schematic Error Found?:The generation of C (label) voltage via U6D (found on the SCR Control schematic) may be incorrectly documented since the same C is used in the CC amp section and screams its purpose is to limit any remote source to max +5V or +10V (not sure which). I've disconnected it from CR26 in the simulation, otherwise, the voltage feedback loop won't work.
How voltage regulation works:Front-panel voltage setting pot R84 emits a 0..10V voltage at its wiper. This voltage (at CR26 anode) is divided in half due to R68+R80 to GND. That voltage (0..5V) is then buffered by U9C (Vout=Vin). U9C output drives the top of R82/R62 (26.1K/105K or 20/80 ratio) divider. The bottom of the divider (yellow) is connected to -OUTPUT (via inconsequential 1K R9). Purple is connected to +OUTPUT/GND. Pink is the mid-point of the R82/R62 (20/80 ratio) divider. U9B compares purple with pink and drives its output such that it brings pink=purple. Q:How? A:Assuming front-panel voltage setting is at max (20V and therefore U9C output is +5V) and +OUTPUT to -OUTPUT difference is 0V (just ramping up). Then U9B +Vin > -Vin because the mid-point of the R82/R62 is above GND. U9B output is fully positive (acts like a comparator). CR21 is reverse biased/not conducting thus allowing Q9 to be shut off via R67, which allows R65 to pull MOSFET gates to +15V (B label) turning them on. The +OUTPUT to -OUTPUT difference starts growing to the point where 20V over R62 and 5V over R82 makes the mid-point 0V. This matches the U9B -Vin (GND/0V). If -OUTPUT overshoots to -20.1V WRT +OUTPUT then U9B -Vin > +Vin which drives the U9B output negative through CR21 turning on Q9 and dialing-back MOSFET gate drive, decreasing +OUTPUT to -OUTPUT voltage. An equilibrium is struck such that the U9B output is at a value that will maintain 20V (front-panel setting knob) across R62.
So what could go wrong to gradually grow the set voltage 700mV over a minute?If the +10V (TP7) stabilizes seconds after power-up (your last post), then test further along: at R84 wiper, at U9C +Vin, at U9C output. If you find at one point it takes one minute to ramp up, then you've found the culprit. Although I don't see the R86/R68+R80 divider the likely culprit, but the R84 pot does have 10mA flowing through it; still, not likely.
There is virtually no current through the purple, pink, yellow, green traces and therefore, the resistors and switches (S1, S2, S5A, S3) in series should not change value (over a minute) due to heating.
The transistors in-line with the cyan trace will experience heating and thus their outputs can change (if given the same base/gate voltage) but this is compensated by U9B servo action; similarly, any other (minimum) load resistors that may heat up like R60 or leaky SCR CR20 (OVP schematic).
This leads me to think U9 (B or C) may change over that minute period. Although, you can't tell with B as it may be responding to Q9 and MOSFET heating changes.
