Author Topic: HP E4421B error 513  (Read 2090 times)
Offline EjTopic starter
HP E4421B error 513
« on: September 29, 2017, 08:32:38 am »
Hi guys,
I'm new here, sorry to bother y'all.....found a E4421B 3 GHz gESG series generator working ok, but it has one flaw: error 513, Het. VCO unlock....nevertheless everything seems to work. Something is wrong with the 1 GHz PLL. Anyone seen this and knows which part should be replaced?
Thanks, Eric
Re: HP E4421B error 513
« Reply #1 on: October 31, 2017, 09:45:30 am »
Solved it by swapping the defective plugin with one from eBay. Not the best way but now I see no more annoying errors  :D
Offline Samogon
« Reply #2 on: October 31, 2017, 04:25:38 pm »
513 oven is cold, usually it disapears in few minutes.
« Reply #3 on: November 08, 2017, 10:12:10 pm »
Your comment is not correct, oven cold is error 514, 1 GHz reference oscillator unlocked is 513.
Offline Samogon
« Reply #4 on: November 09, 2017, 06:56:35 am »
Oopsy, my bad
The following users thanked this post: Gyorgy Albert
« Reply #5 on: November 11, 2017, 03:13:02 pm »
What forced me to solve it this brute force by forking out $$$ is the fact HP doesn't publish any real schematics, that's the real bad!
The reference 10 MHz oscillator to which the 1 GHz PLL is locked on this newer board is smaller then on my original plugin.
