So I gave my father my old monitors some years back when I bought two new larger ones. 2x HP L1940T monitors. I also have a third one on top of my server rack which is occasionally used.
All 3 owned since new and never abused or stored anywhere and are in immaculate condition like new.
Beginning of December one of the two my father uses on his PC started randomly "pressing the menu button on it's own" and also showing the message "OSD Lockout" randomly (which is activated by holding the Menu button for a few seconds).
After a couple weeks it then started "pressing the power button on it's own" as well
I took the button PCB out thinking the buttons might be stuck and I also checked them with my multimeter and they working fine are not getting stuck down. I gave them a clean with contact cleaner to be safe.
No obvious problems elsewhere on the PCBs that stood out, but I never had time to look in more depth during December as I was working constantly thanks to panto season!
So I swapped the monitor with my server rack one and all was good temporarily.
Last night now the original server rack monitor has started having the same fault. Same model Monitor bought at the same time. The third monitor is still alright for now.
Tried the monitors on another PC and with different leads and the fault is with the monitor. It happens regardless of using DVI or VGA input also.
Anyone have any clues as to what might be causing this fault and where I could start looking?
The monitors otherwise work fine. Just unusable in this state.
A quick google found this page but is it archived. If anyone knows how to view it?
https://h30434.www3.hp.com/t5/contentarchivals/contentarchivedpage/message-uid/5081431Service manual with schematic:
https://www.manualslib.com/download/918483/Hp-L1940t.html
