Author Topic: HP Oscilloscope Issue  (Read 1868 times)
Offline AardvarkM31
« on: December 03, 2021, 02:30:14 am »
I purchased a used HP 54600B oscilloscope. I didn't realize but it was missing the brightness adjustment knob. I seen online that there is some common issue with the brightness of the scope failing. The scope seems to work well and the brightness is fine as it is. Without having the knowledge to pull it apart, does anyone know of a fix for that or similar issue that does involve removing the adjustment switch a a visible clue?
Offline Wallace Gasiewicz
Re: HP Oscilloscope Issue
« Reply #1 on: December 03, 2021, 10:38:17 am »
If you can see the stem of the potentiometer in the hole. Just get another knob.
Pics of the 54600 show a knob but sometimes these adjustments are just flat screw heads.
I do not know what your particular damage might be.
The following users thanked this post: AardvarkM31
Online oPossum
« Reply #2 on: December 03, 2021, 02:58:06 pm »
The brightness knob is the end of a shaft that extends about 4 inches into the 'scope. The pot it connects to has a D shaft.
Offline AardvarkM31
« Reply #3 on: December 04, 2021, 06:03:18 am »
Howdy Wally,
    Nope, nothing can be seen in the opening. May have to dig deeper....
Offline AardvarkM31
« Reply #4 on: December 04, 2021, 06:08:11 am »
Hello oPossum,
   So that is what it looks like. Thank you for the picture, I had thought it was a mounted potentiomer and a knob on the outside. That shaft has been removed or is broken inside. Are those parts still even available? Just learning the scope and haven't really realized a problem with the adjustability yet.
Offline james_s
« Reply #5 on: December 04, 2021, 06:34:46 am »
I don't know if that part is still available but I'd be kind of surprised if it is still manufactured. It looks like you could fabricate something fairly easily though, some kind of round plastic rod stock coupled to the pot with a piece of rubber tubing ought to work.
« Reply #6 on: December 04, 2021, 11:15:47 am »
James has the right idea. You can get clear rubber like tubing from ACE hardware for about 20 cents a foot. It is flexible for liquids but firm enough for this function.
I just bought some for my suction on my solder extractor. Comes in several diameters.
Craft stores like Michaels probably sell  plastic "stock"
Harbor Freight sells plastic "welding rods" never used them but they might work.
You can heat the end of the clear rubber tube with hot air to make it fit better.
Online oPossum
« Reply #7 on: December 04, 2021, 01:45:53 pm »
Offline george.b
  • Country: br
« Reply #8 on: December 04, 2021, 06:40:14 pm »
If 3D printing is a viable alternative for you, this might be compatible: https://www.thingiverse.com/thing:4609646
Offline james_s
« Reply #9 on: December 04, 2021, 08:27:11 pm »
Oh yeah, look at that. I often tend to overlook 3D printing since the vast majority of what the consumer machines are used for is making useless trinkets but that's exactly the sort of thing that a 3D printed part might actually work pretty well for.
Offline CaptDon
  • Country: is
« Reply #10 on: December 04, 2021, 09:11:19 pm »
Remember it MUST be a plastic shaft since the brightness pot is a thousand volts below chassis ground!! You could use a metal coupler at the pot end and then a plastic shaft. I have seen FR4 1/4" shafts readily available and TEK uses lots of 1/4" and 1/8" FR4 shafts in their products.
Online oPossum
« Reply #11 on: December 04, 2021, 09:51:39 pm »
The 5462x shaft (top) is a little longer than the 5460x/5464x shaft (bottom) and the hole in the front panel is larger.
Offline george.b
  • Country: br
« Reply #12 on: December 05, 2021, 02:58:58 am »
Oh, so much for that idea, then... thanks for pointing that out!
Online oPossum
« Reply #13 on: December 05, 2021, 06:42:26 pm »
Just in case you don't already know this - press the Print/Utility button and then simultaneously press the 2nd and 3rd button under the screen.
Offline AardvarkM31
« Reply #14 on: December 06, 2021, 03:09:36 am »
Thanks, I should be able to facilitate a replacement. Wish I was into 3D printing. Knock that part out easy :)
Offline AardvarkM31
« Reply #15 on: December 06, 2021, 03:11:19 am »
Yep I think I can!!! Maybe should start a thread for a 3D printed version. :-//
Offline AardvarkM31
« Reply #16 on: December 06, 2021, 03:13:15 am »
Thanks for looking into it. Oh well, day late and a dollar shy..............
Offline AardvarkM31
« Reply #17 on: December 06, 2021, 03:19:10 am »
Howdy oPossum,
   It looks like some others have beat me to the 3D printer idea. Now I just have to buy the printer and learn how to do it :scared:
What does the pressing those buttons do on the HP oscilloscope?
Thanks for your time
Oh never mind, I just found out. Outstanding sensed of humour!!!
« Last Edit: December 06, 2021, 03:24:14 am by AardvarkM31 »
Offline james_s
« Reply #18 on: December 06, 2021, 03:51:15 am »
From what I've seen with some friends of mine that have 3D printers, it's a tremendous amount of screwing around to get it to do anything useful. There are online services where you can have items printed for a fee though, you might look into that.
Offline george.b
  • Country: br
« Reply #19 on: December 06, 2021, 11:08:25 am »
In my experience, well, I don't really mind it. Sometimes a part won't come out just right the first time, but I'm probably more at fault than the printer, especially when printing with more finicky materials such as ABS. Buying a 3D printer was worth it for me. For just the one part, though, I agree, looking into a printing service may be a better option.
Offline james_s
« Reply #20 on: December 06, 2021, 06:53:38 pm »
3D printers are for people that want to tinker with 3D printers. 3D printing services are for people that just want a printed part.
« Reply #21 on: December 06, 2021, 09:02:33 pm »
I ordered and received "feet" for my Tek 475 scope. They are very nice and made with a 3 D printer.
I believe that the fellow who made them needed feet for his scope and then made a bunch to sell as they are known to deteriorate even with good care.
Offline AardvarkM31
« Reply #22 on: December 07, 2021, 04:05:52 am »
The empirical data I've collected seem to be that it takes a bit of doing!! Will try that online idea!
Offline AardvarkM31
« Reply #23 on: December 07, 2021, 04:09:29 am »
Yes it does seem to require experience and trials. More than it is currently worth to me. I will see if I can dig up a online site as suggested!
