Author Topic: HP power button neon  (Read 317 times)
Offline veedub565Topic starter
« on: January 04, 2025, 03:36:23 pm »
Hi, does anybody know a source of replacement neon's for the older HP illuminated power buttons (see picture)
I tried goggling thr HP part number but haven't come up with much.
And an image search just throws up lots of hits for miniature bulbs, which it's isn't it's definitely a neon (95v in this case)
Offline DLJ
Re: HP power button neon
« Reply #1 on: January 04, 2025, 03:59:37 pm »
I googled "T1 neon" and found this https://www.ebay.co.uk/itm/293178384132
No idea if this seller is any good, or even if this part would work for you.
It might just be the entrance to a very deep rabbit hole.
Happy hunting.
Dave
« Reply #2 on: January 04, 2025, 04:03:39 pm »
Ah perfect, thanks. I didn't even know it was called  a T1 neon, or sub midget flange
Offline schmitt trigger
  • Country: mx
« Reply #3 on: January 04, 2025, 04:05:34 pm »
You may receive suggestions to replace the neon with an LED, by adding a diode and changing the limiting resistor.
Unless you absolutely cannot find a suitable replacement neon, I would not recommend it. I may be prejudiced, but I positively love the soft neon glow.  And you would keep your vintage device, well, vintage.
Offline factory
« Reply #4 on: January 04, 2025, 05:30:52 pm »
They are usually an A1H neon, the one linked in reply #1 is too small.
« Last Edit: January 04, 2025, 05:34:14 pm by factory »
Offline Dave Wise
« Reply #5 on: January 04, 2025, 05:50:37 pm »
Edit prompted by "factory".  I misspoke in my original post.
My HP 740B DC Voltage Standard/Differential Voltmeter was made with two type A1G neon lamps.  The envelope size is called T2, and the base is Midget Flange.  One is powered by mains AC, the other by DC.  I bought a pack of new-old-stock A1H lamps off eBay.  (A1H is easier to get cheap than A1G.) The new lamp in the AC-powered spot is reasonable brightness even running at A1G current.  It is still going strong, but the DC-powered one darkened after a few months due to metal sputtering onto the glass.  This is a known failure mode, neon lamps prefer AC.  I replaced that one with a Dialight LED lamp.  With no circuit changes, the existing resistor gave the right brightness and it will probably outlive me.  Part number 586-1101-005F 24V and tip negative, 586-1101-105F 24V and tip positive.  I have two 740B's, and one is positive and the other negative.
Just like cheap Christmas lights, if you run a LED off AC it will flicker unless you add a reservoir cap.
HTH,
Dave Wise
« Last Edit: January 04, 2025, 10:53:09 pm by Dave Wise »
Offline factory
« Reply #6 on: January 04, 2025, 06:12:13 pm »
The 740B should have a A1G according to the manual, this is a lower brightness part, if it's getting burned out quickly, the supply voltage is either too high, or the series resistor value too low.
The lamp size of both A1H & A1G is T2, have a read of the GE glow lamp manual if you don't believe me.
Additional info: The number codes used for the lamp/bulb diameter are in eights of an inch (⅛"), for some unknown reason the more modern A1H & A1G are sold as T1¾.
« Last Edit: January 04, 2025, 06:30:37 pm by factory »
« Reply #7 on: January 04, 2025, 08:07:07 pm »
Looks like there could be a lot of different permutations depending on which HP instrument it's fitted to.
in this case it's for an 8447F and the HP part number is 2140-0244, mfr part number is listed as A1H
So an A1H T2 midget flanged neon is what I need byt hte looks.
« Last Edit: January 04, 2025, 08:14:02 pm by veedub565 »
